1995 JOHNSON 200 CARB FLOAT ADJ
RHB
I am cleaning a carb and noticed the float is not adjusted per manual. With the float chamber inverted the float is way beyond flush with the gasket surface. How is the adjustment made to set the float to the proper height? What would result if the float is not set to the proper height?
