ljstephens11
Thread starter- Joined
- Jun 27, 2013
- 2
While out boating, we stopped to take a swim and when I went to start the engine, everything was dead. (Ended up being a bad connection on the battery switch). When we got the boat towed back in we could not manually pull the motor up to tow it home until we loosened one of the bottom nuts on the trim motor. (Where the tube goes into the motor) Now that everything is working electrically, I cannot get the trim to work. The motor runs, but it will not go up. (It will go down slowly) I have tried to refill the fluid as best I can, but the majority of it pours back out and I know that I haven't replaced the same amount of fluid that was lost when we initially pulled it up.
Here are pictures of what I have. I don't think that it is a factory part. I am a mechanical novice, so any and all help would be appreciated. Thanks in advance
p.s. The pink fluid in the picture is runoff from overflow from the fill cap. It is not leaking there.
