The engine starts and runs fine usually. Cruising at about 3000rpm it will hesitate briefly like its not getting enough gas. Like someone flipped a switch. Once in a while it will cut off, but start right back up. Lately it has been getting worse. Seems to idle fine at first but once it cuts out idles rougher until you have to go back to the dock. I checked for air leaks in the fuel line, Replaced lines, checked all hose fittings , internal tank and water seperation filters and fittings.New bulbs on fuel and oil lines etc. New temp sensor on one side. Spring tune up at dealer included all carbs rebuilt and changed spark plugs etc. It seems to use more oil than needed. The gas is clean. New ignition switch.Brand new VRO pump and problem still exists. I fish many tournaments and this intermittent problem has went from bad to worse over the FY03 season. Now it will not stay running one minute and run great the next. Always eventually cuts out. Interesting to note that after the most reasent repairs (fuel lines etc) It ran better than it had in days in fact I thought I fixed it. Then BAM cuts out and cuts out again and again. I am starting to lean towards the power pack and sensor? I am not sure where to turn or what to do next. Any suggestions? Thanks. Southbranch.
