1994 Johnson 40hp vro dies
walleyechaser
Engine starts then dies after about ten seconds of running. The fuel bulb is soft but pumping it to try and keep the engine running does not help.<br />The engine will restart then die again and again<br />Any ideas?
backdraft
Re: 1994 Johnson 40hp vro dies
Walleyechaser, sounds like the check valve in the squeeze bulb has broken. Attwoods are notorious for is and I have replaced quite a few for customers. Use only genuine OMC {BMC}. Hopefully that will help. nevjb
rickdb1boat
nevjb <br /><br />DITTO on the fuel line. OMC all the way!
walleyechaser
We replaced the fuel line bulb and everything is fine in motor land Thanks
