1994 evinrude 200hp
luv2fish1987
I have a 94 evinrude 200hp that will idol on the water hose and in water but when i try to get on plane it bogs down and will not get on plane it appears to be leaking fuel out of the bottom carb on each side more so the lowest placed carb also when running on the hose it will backfire every once in a while any advise would be great thanks in advance.
fhhuber
First thing is fix the carbs because a fuel leak plus backfiring is going to turn your boat into a bonfire.
luv2fish1987
Plan on tearing them down this weekend boat has sat for a while so I am thinking the float may be stuck the fuel is leaking out of a hole in the middle of the carb in between the throat and drain screw.
Chrisravosa36
Agreed with fhhuber, you should differently look into the carb cleaning/ rebuild, see if you see any holes or anything in the bowl or the carb.
Chris1956
Honorary Supreme Mariner
You will need six carb kits and a service manual, to set the floats and idle mixture screws correctly. I also recommend a link and synch after the carbs are clean.
