Ghost_rider
Thread starter- Joined
- Aug 19, 2013
- 12
I picked up a boat with a 50 hp johnson and was wanting to buy another prop for it cause the one on it has some road rash on it. Not bad but figured it could use one. I was talking with a boating buddy and he said that you have to run it at the rpm designed for the motor. Well the tach doesnt work. I checked the ground and the hot wire from the ignition and there is power. How do you check the sending wire with a voltmeter? Also there is a few loose wires. One is a yellow wire with a red strip. Also there is a brown wire that is bare and not connected coming from the motor.
Also can someone reccomend a prop for this boat? It has a 12-1/4x15 on it now. Its a mon ark pro 160.
Thanks for the help fellas
