SOCALBOATER11
- Feb 15, 2014
- 5
I changed the fluid in my outdrive 1994 4 Winn's 180 5.0. I took lower middle and upper plugs out. I filled from the bottom but at no time did any fluid come out the center vent. I drained 64 oz. and pumped back it about 70 and the dip stick shows over full. Should I drain some fluid out and why did no fluid come out the middle vent. With putting in 64 oz. do I need to worry about air and is there a way to purge it out? It only has 2 bolts where the dip stick is and they sit lower than the dip stick. Thank you.
I do think I have the OMC/Volvo.
