1993 omc 200 will not turn when primer(choke) engaged
fiveonadub
auquasport2.jpg Hi everyone,
I have been lurking about in this forum for quite some time. I am grateful for all of the fantastic money saving info I have found here to fix my piece of crap boats.
I have bought another piece of crap and need some help with it.
'85 21' auquasport 200 express w/ 93 200 omc outboard
I have restored the look of the boat
Engine fires and runs after an incredibly hard start. I will be cleaning plug wires and junk later.
My problem is the choke or primer thing. When I engage it by pushing the key in then turn the key to start...nothing. When I let the key out, the starter engages.
In other words, the starter will not engage at the same time as the primer is engaged.
Please help me figure this out.
auquasport1.jpg auquasport3.jpg auquasport4.jpg .
jakedaawg
need a new key switch most likely. Remove key switch and perform resistance check to verify. If I am thinking clearly you need low ohms between the B terminal and the S terminal while pushing in with the key turned all the way clockwise.
fiveonadub
On other motor I have had, the key press activated a choke...
this one is different..
after running it for a couple of weeks, I have found that it works so I will leave it as it is.
From what I understand about this motor is that primer solenoid sprays a bit of gas straight into the cylinder. So I just hold it in and count to 5 and let it out then turn and it kicks right off.
If it ain't broke, don't fix it. Until it gives me headaches, I am going to leave it alone.
Thanks for the tip though.
Bosunsmate
Nice boat and tow vehicle, hope youve got a good name in mind for her.
One thing about the choke is that you should turn the key and then press the key in while you have the key turned.
If you press the key in first you lose fuel pressure as the fuel pump isnt cranking until the starter is
