1993 Crownline 210CCR fuse panel??
Oliver378
trying to figure out why the stereo is not working as well as a couple lights and thought I would start with checking the fuses. I can't find the fuse panel. It doesn't appear to be amongst the gauges at the helm? can't see anything looking behind side panels or the stern of the boat around engine compartment. The boat is new to me and I don't have a manual. does it even have one? anyone else know if and where it is located? 1993 Crownline 210CCR..cheers
gm280
I have no idea if your boat has a fuse or circuit breaker panel. However, if it doesn't, that would be the very first change I'd make to the boat. Usually there is a fused setup at the battery and a 10 gauge wire coming from there to the buss bars (positive and negative) and then through fused circuits for each breakout circuit. So if you trace the wires back and find out there is no setup like that, then take the time to rewire it... JMHO!
