1992 mercury classic 40 hp
fivespot
where is the thermostat located on this motor 4 cyl 40 hp 2 stroke oil injected ?
I don't think there is one on that model.----Serial # of your motor ?
fivespot
the engine temp sensor went off today and the water from the tell tale was very warm.I am running in fresh water and it took about15-18 min for alarm to sound
That family of engines never used a thermostat.-----Time to do a compression test.--------Change impeller every 3 years from now on.
I would pull bypass covers and have a look at pistons and rings.----Then again some gauges do read different than others.-------Is motor cooling properly now ?.
fivespot
going to change water pump and try again on week end I will post results. thanks for the input racerone
fivespot
are the bypass covers you are reffering to the exhaust plates on the left side of the motor looking forward over the motor toward the bow ?
