1992 Johnson 225 V6
Mattash
Help!!<br />I run this 225 Johnson for 1-2 hours at mid to full throttle, idles fine, runs at 5500-5700 WOT.<br />Recently I trolled for about 1 hour, stopped in a tight spot on the river and used reverse for about 10 feet and shifted to forward. When I went back to forward it seems as though I lost 3-4 cylinders and the motor just bogged down. Started the beast the next day and all ran well. Any ideas??<br />Joe
angus63
Re: 1992 Johnson 225 V6
Joe<br />There is a shift switch which shuts down 1-3-5 cyls when shifting. I would start there if it occurs again. Located near the control linkage meets the shifter arm. Good luck......
