1992 johnson 120 hp not getting up
Redfish92
can anyone help me out? I have 92' Johnson 120hp model# VJ120TLAND. its not getting up. AT WOT IT DOES 2000rpm and 8-10mph in the water. on the trailer its revs up and acts perfect, runs and idles good. I have checked and changed spark plugs. I just replaced all four coils and wires and boots. I've changed the power pack out. I just put new VRO pump and pulse limiter. the fuel lines from the tank to VRO were just replaced along with pump bulb and fuel filter and made sure the tank was breathing and not vapor locking. also just added and fuel/water separator. brand new batteries, I have checked the charging system and checked to make sure all plugs are firing, which are. I have done compression tests on all four cylinders and all tested good. ANY HELP I COULD GET WOULD BE AWESOME.
Honorary Supreme Mariner
I guess it only sounds good to you on the hose.------It will rev up on 2 of 4 cylinders.---Checked flywheel magnets ?-----Did this problem show up suddenly or did it develop over a period of time ?
Redfish92
have not pulled the flywheel yet. the boat ran good when I first took it out. yea it had been sitting up and I sprayed carb cleaner through the jets to get it fired. took it out on the water did great. then decided to do some upgrades like I mentioned before and now its acting like this.
Redfish92
wouldnt the flywheel magnets be good if its putting a charge on battery
Redfish92
I believe I fixed the problem. when I changed the power pack theres a metal clip that hold the wired down coming from timer base and it was to tight that the timer base linkage wasn't advancing all the way forward. stupidity on my part. thanks for the help guys!!
