Re: 1992 Force 120HP
It's hard to figure out what exactly you are talking about, are you talking about possibly needing to re-shim the gears or are you talking about having issues putting the lower unit back on the motor? If you are talking about re-shimming, my understanding is, if you haven't changed driveshafts or driveshaft bearings then you should just be able to put everything back together with existing shims (if any).
