1992 Evinrude 9.9 throttle stuck
jadedragon
I have a tiller handle throttle type 4, rope start, and would like to know how to determine the failing part. How to I disconnect the throttle cable from the carburetor?
flyingscott
The cable disconnects from the side of the motor just past the recoil. Also make sure the knob on the end of the tiller handle is loose as that is a throttle lock and can prevent the handle from moving
oldboat1
Curious....How do you mean the throttle is stuck? If it won't fully throttle up in neutral, for example, that would be normal -- needs to be in gear.
