1992 Evinrude 120 VRO Surging
will7670
Hello,
I am having some trouble with my 1992 120 VRO (VRO is disconnected). The boat idles ok, however when getting on plane and once on plane, I have some surging problems. When trying to get on plane, and having the throttle wide open, the engine will begin to surge just before it is about to "jump the wave". I am usually still able to get on plane, as there is still enough power to achieve plane when surging. Once on plane, the surging continues (between 4000-4200 rpm). After about a minute of surging, the rpm levels off around 4000, and stay there.
It started when I took the motor to have a tune up, and clean the carbs at a local boat mechanic. I then returned it to them, and they claimed the surging was not due to them, and was a coincidence. They then replaced the fuel pump with an electric one, replaced the fuel lines (up to the motor), primer bulb and the fuel filter. None of this fixed the issue.
I have checked the fuel flow (up to just before the carbs, by letting the electric pump run with the motor off) myself, and there is a lot of fuel coming through the lines. My gut tells me that there is something up with the carbs after they were cleaned.
Just wondering if anyone had any ideas.
Thanks,
Josh
fireman57
Try cleaning the high speed jets again. Might be a piece of crud that gets in there. Also, you should be turning more than 4200 rpms at WOT, might have dropped a cylinder or getting intermittent spark to one.
jakedaawg
In addition to above...
Improper float installation or adjustment.
Compression test this motor.
will7670
Hi guys,
Thanks for the replies.
Before they "cleaned" the carbs, my WOT rpm was about 5400-5700 depending on the trim or prop I was using. It only began to rev lower at WOT once they were cleaned.
Cheers,
Josh
fireman57
Sounds like you are dropping a cylinder. Check spark when this happens. You will want an open air spark tester. about 12 bucks at your local cheapo auto parts store.
will7670
OK, I will do both of these tonight.
For the spark testing, does the engine need to be running? Or can I disconnect all leads, and test them one at a time while cranking the engine? Also, any idea on the gap size that I will need for this engine?
Thanks for the input guys, I really appreciate it.
Josh
will7670
I don't think he tank or hose is the issue. the fuel flow from the tank is good. I pulled the furl line off just before the carbs and checked. The electric pump is pushing lots through the hose.
fireman57
Disconnect all leads for spark test and do them one at a time. Also when you pull the plugs for compression test inspect them and see if they are wet or dry indicating getting fuel or not.
will7670
Thanks!
I also had the airbox off yesterday and noticed that the throttle plates do not open fully when my throttle control is pushed all the way forward. The throttle mechanism only pushes them to a little over 3/4 open (not fully turned horizontal).
fireman57
Adjust them so they open all the way or take it back to the mechanic and tell them to do it as it should have been fixed when you got it back. The other tests you can perform this weekend in no time at all. They really need to be open all the way.
jakedaawg
If they installed an electric pump they are morons and I would suggest never taking anything to them...plain and simple, an electric pump on this is an asinine thing to do. Difficult to do right and unsafe if done wrong.
jakedaawg
If you are going to do it yourself you need a factory manual, and perform the link and synch.
otherwise, a dealer or a shop with a mechanic who actually deals with older evinrudes...
you will know if they are any good if they insist on removing the electric pump before they will touch it...
will7670
They told me that the electric pump operates below the pressure needed to overflow... or something like that anyways. It was last summer. Don’t exactly remember. So far it has had no leaks or overflow, even when not shut off right after shutting off the motor.
Why is is the electric pump such an issue?
Thanks for the help!
