1992 90 hp force jetstar wont start
jetstarr1
My 1992 90 hp inboard force jet boat shelled out the flywheel magnets! I bought used flywheel off e-bay, now motor is kicking back aginst the starter, wont start. I compared flywheel to flywheel and all looks same even same part #. Could the timing be off some how? Flywheel Key is in good shape. It dose try to hit and at times it back fire. Need help any idea ?
jerryjerry05
Remove the plugs and do a compression test.
Turn the flywheels upside down and see if the timer at the flywheel key is the same as the old.
Profile, location?
You might be close to someone who can help.
jetstarr1
Found problem tigger magnett is 180 degrees out. Wrong flywheel. Beware what you buy off ebay!
jetstarr1
Found problem trigger magnet is 180 degrees out. Wrong flywheel. Beware what you buy off e-bay! Dose anybody know where to get parts for this 1992 90 hp force inboard jet drive Serial #od 150239 Jetstar 13' by ultra-nautics.
jetstarr1
Now have new problem. #3 cylinder fouling plug real bad, pull plug out, turn motor over, fuel sprays out plug hole and runs down wall. I found new flywheel at merc dealer in wi. Haven't got motor started yet. Can any body help.
pnwboat
Bad fuel pump diaphragm? I may be mistaken, but I believe the fuel pump is driven off the intake pulses from #3 cylinder. If the fuel pump diaphragm gets a hole in it, or is torn, it dumps gas into #3 cylinder through a vacuum line that runs from a 90 degree fitting on the by-pass passage on #3 cylinder to the fuel pump.
