Down and Out in Va.
Thread starter- Joined
- Mar 4, 2003
- 5
This outboard starts good and runs when it wants too. The problem is when it is running good it all of a sudden it will cut back to 1/3 open speed<br />and will not pick back up to normal speed. The next two or three times out it will run good. Then<br />the next time the same thing again only 1/3 open.<br />I have had 1 year of Johnson trouble!! I have replaced the following, fuel tank, lines from tank to motor, squeeze bulb, fuel pump and all lines,power pak,coil,and pluges and wires. Need all the help you can give. Thanks!
