1992 25 hp Mercury on pontoonboat! Put in reverse works little than grinds!
TonyJSki
Found 2 parts laying down inside bottom of engine but don't know where it goes! Not sire this has anything to do with reverse problem. Could not find a good picture with parts diagram. Even called Marina!
That wire goes from carburetor area to under the flywheel.-----Part of timing advance for starting and warmup.----Check oil in lower unit.---Check shift adjustment.
