1991 Sunbird Quit Rider 115 HP Jonson TILT TRIM SENDER UNIT Location
Ant-Knee
Hello All,
I am working on a boat right now which is a 1991 Sunbird with a 115HP Johnson outboard ( Quit Rider set up)..
There seems to be a problem with the tilt/trim sender unit location.. There is one on there but it is not or cant be in the right location as the contact leaves the lever to tell the sender whether it is up or down position..
If you have the same set up with the tilt trim working can you please tell me where the sender unit is located ...
Thanks for any help
