1991 Johnson 120 V4 No Run
MStowe13
I have a 1991 Johnson 120hp V4 that will attempt to start but will not continue running. Sounds to be missing on 1 cylinder. I have gotten it to run for about 10 seconds but that was only once. Has anyone had similar issues on this motor or similar motors?
interalian
V4 will idle just fine on 3 cylinders. Have you done a spark test? Should jump 7/16" easy using a spark tester. Compression test is a good idea also.
Did you just buy the motor or has it just started exhibiting this problem?
jakedaawg
Yep
Step one is a compression test
Step two is an opennair gap spark test set at 7/16"
Step 3 is a fuel sample from fuel line into a clear container
Report back results
