Hello everyone,
I have a 91 force 9.9. While on the lake yesterday the motor ran like a top but then after I started her up and headed back to the dock she lost power and sounded like she was running on 1 cylinder. So while it was running I took of the top plug wire and she was still running, then the bottom plug I took off and the motor died. I limped back to the dock and when I got home I check the wires for spark and the top wire was getting none while the bottom was getting spark. So to my question..... I sorta figured out that I probably need a new coil kit with wires. So i got the nut off the flywheel and noticed that there are not any holes tapped on the flywheel to use a conventional puller. I tried renting one from autozone which was a three leg puller but would not fit and it was the largest they had, which was an 6 inch. Is there a special puller that I need to use or should I just heat the shaft up and smack it with a hammer while prying with a pry bar up on it? Any help would be greatly appreciated. Thank.
