1991 Evinrude 150 HP Compression Test
haxsaw
What are the steps I need to take to do this, is there anything I need to make sure I don't do during the test?
S.T. Marine
Re: 1991 Evinrude 150 HP Compression Test
Remove all the plugs. Keep spark plug wires away from you so you dont get shocked during the test. Attach the gage and turn the motor over several times 5-6 to get the reading. Log info and repeat for the other cylinders
Backlash
Generally a good idea to disable the ignition before cranking the motor. ;) <br />Backlash
S.T. Marine
Ahh if your carefull no need...... Or else zapp.....!!!
Backlash
Actually, I've heard of instances of blown power packs as a result of cranking with ungrounded plug wires. <br />Backlash
