1991 70hp Force lower unit filler plate
I have a 91 70hp force. in taking off the water pump to change the oil seals, i see the the filler plate pn 818226A1 is just held in with silicone glue and has a big gap between it and the water pump bottom plate. also filler with silicone.
what does this filler plate do?
is it necessary?
and is there a better way to attach it than silicone?
thanks
jerryjerry05
The way I understand it, it's supposed to keep exhaust from going back up into the engine.
Just do it the way the factory did.
Ok. So how did the factory install this? I'm looking at the factory manual and I can't find anything specific to the installation of this part.
In the photo on pg 4a-4 it does look like it is siliconed in place. But is just a guess.
