1990 Mercury 40hp 2 stroke. Oily milky goo coming out of exhaust ports
Justin777
Hey everyone. Any ideas or info would be a great help.
Last fall I did an impeller job on my boat. Everything worked fine after that. Fished a few times in the fall and winter on the Niagara river. No issues drained water and stored boat safely in down position.
Spring 2016 did a bottom end fluid change and fished a couple times in April. Again no issues at all.
Went out yesterday on lake ontario trolling for salmon. Again boat ran awesome no issues. After our trip, put the boat on the trailer, and went to weigh in our fish for a derby, came back to my boat and my exhaust ports and prop were oozing brown oily Milky substance checked bottom end fluid. No issues there all clean no water.
When I got home we dropped the lower end off pf the motor and all in the exhaust ports, around the water pump and up in mid section were the drive shaft splines in had this milky brown goo.
Water pump seal?
Water jacket leaking into exhaust?
Bad cylinder?
Trying to see if anyone has any insight on the issue before I take it into a mechanic.
I attached a picture of the milky goo coming out the exhaust holes and ports
