1990 Mercury 2.5 black max 200
CaptDiz
I've battling running problems last week with a negative vent /collapsing primer bulb. I finally eliminated everything except pick up tube blockage. I removed and screen was clogged with trash. I reinstalled pick up tube without screen to insure it would not clog on charter yesterday. Motor ran fine all day in rough seas and various throttle positions. I returned to dock and did my normal shutdown procedures. Today , had a late afternoon charter, boat was slightly running rough and didn't want to stay idle. Got underway , she would not accelerate, only bog down and run less than 2500 rpm. I did dump racor and found several particles in gas. On side note, while motor was idling me back to dock, I had no tilt trim , then back at dock after tying up, I had no key switch ignition power, gauges would power up but no ignition when turned key . I messed with battery connections wing nuts and it kicked over, but running barely at idle. I can engage in neutral and it will run. Also my water temp gauge would not come up on initial departure from dock and tach was bouncing , all other gauges worked fine. (Fuel, water pressure,voltage). Any ideas to start ? Remove all fuel and reinstall screen?
Thanks for any feedback,
Frustrated Capt!
Chris1956
Clearly you have some electrical issues. Get those straightened out and see how boat runs. Wing nuts on a battery is a bad idea. Clean connection and replace with nylon locknuts.
