tuandabrainz
Thread starter- Joined
- Oct 9, 2005
- 3
I have a boat with twin 1990 200, VJ200TXESM motors. I had issues with the starboard motor really giving me a hard time to get it started. In fact, I would have to spray fuel in a squirt bottle directly into the carbs intake to get her to fire up.I figured that the problem was the fuel pump. It has the VRO2 pump, but the oiler has been bypassed and I am running premixed fuel at 50:1. I got another pump off eBay, and although it is a different part number, it appears to be the same size, has the same fittings and looks like the same animal. However, once again could not get the engine to start unless I put fuel directly into carbs. I have eliminated the fuel tank as an issue, I put the fuel line into a 5 gallon gas jug with brand new gas premixed. I replaced the primer solenoid. I replaced the primer bulb. Still get the same result. I don't think this is a spark problem because when I spray the fuel the engine fires and runs for a bit, I assume until it uses up the gas in the carb float reservoirs. I finally took the pump off the port motor, which primes and starts up every time without hassle. Now, the motor will turn over and run for about 2 seconds and dies. It will not start again until I spray gas. She will not stay running like before, and I think that the change might be I have flooded her with too much fuel from the bottle. Is this actually a fuel delivery problem or am I barking up the wrong tree? Starting to pull my hair out on this one and any help would be greatly appreciated.
