irnman1827
Thread starter- Joined
- Aug 6, 2005
- 12
Hi,<br /><br />Hope this all make sense.<br />I am having problems with my tilt & trim system this year. The system worked OK last year, but did settle some. This year, first time on the water, I was fishing w/ the motor raised (and off) and I heard a couple of fairly loud "pops" from the direction of the motor. The motor did settle. However the motor would no longer lift. Upon closer inspection, 3 of 5 bolt heads were broken off on the trim cylinder and it was leaking fluid. I removed the trim cylinder and the actual cylinder was skewed, not allowing the piston to move. I was able to get the cylinder straightened so the piston would move properly. I put the trim cylinder back together and the trim portion seems to be functioning fine. Now the tilt will not lift the motor. There does not appear to be any fluid leaks and seems to have bled the air out. I removed the tilt cylinder from the motor and it functions properly without the weight of the motor. Any ideas why the tilt will not function under a load?<br /><br />Thanks alot,<br /><br />Jeff
