1990 Evinrude 70 hp VRO
Philby
First time out this season, ran like a dream for 10 minutes thaen lost power.<br /><br />Number two cylinder isn't working. It has compression, it has a good spark, it just won't join in with it's friends.<br /><br />Anyhelp ?
Dhadley
Re: 1990 Evinrude 70 hp VRO
How much compression compared to the other two?<br /><br />Good luck!
ob
What leads you to believe that #2 isn't firing?Is the sparkplug bone dry on # 2 ?
Brew
Hi Philby,<br /><br />I had a similar problem last summer. Turned out I had a blocked high speed jet in one of my carbs, preventing fuel from reaching the one cylinder.<br /><br />Good luck!<br /><br />Brew
Philby
Dhadley<br /><br />Similar to the other two. Can't remember exactly, but very close.<br />I know it isn't firing on number two because I can take the lead off with on two without change. On one and three it stalls.<br /><br />If it is the jet you'll need to talk me through the carb job.<br /><br />Thanks
Brew
Philby,<br /><br />Removing, cleaning and replacing the carbs is a fairly straight forward process, but if you've never done it before, I would recommend spending a couple of bucks to get a manual. It will have step by step instructions along with diagrams to help you through the process.<br /><br />If you are going to go to the trouble of removing the carbs, I would also buy the necessary "carb kits" from your local dealer. The kit provides you with new gaskets and carb floats to replace the old ones. You might as well replace them while you've got it apart.<br /><br />Good luck.<br /><br />Brew
Philby
Thanks Brew<br /><br />Am reading the manual as we speak.<br /><br />I'm sure they don't need all those screws !!
