1990 evinrude 60hp tilt/trim
cuta31
Hey everyone,
New to the forum and just picked up a new to me boat. It is a 16ft lund aluminum with a 1990 60hp evinrude VRO. On my first trip out I was having issues with the tilt/trim. Under more than 1/2 throttle the motor would drop right down almost instantly. Also under throttle it would not trim up. With under half throttle the tilt and trim appears to work fine so i don't believe it is a pump or motor issue. Any ideas what it could be? I consider myself mechanically inclined so hoping it is something i can fix myself.
flyingscott
It could be the manual release on the right side is loose tighten it back up or low fluid. When you have it in your yard raise the motor all the way up and check the fluid. When you are looking at the trim system the big screw on the reservoir opposite the motor needs to be removed. The fluid should come out of the hole if not put more in and run it up and down a couple times repeat until fluid comes out. Right around the corner from that is the manual release make sure it is tight. Sounds more like a fluid issue though.
Fed
Are you sure this is not happening only in the tilt range?
Tilt ram is not designed to hold against engine power, it should drop down until it hits the trim rams.
cuta31
Fluid level is good and the manual release is tight. And it is definitely occurring in the trim range, under throttle the motor will drop down until it rests on the tilt pin. Is it possible I have some sort of internal leakdown? As there is no sign of external leaks.
