1990 Evinrude 225 stator output
mark munro
What is the stator output supposed to be for a 1990 Evinrude 225? My service manual doesn't semm to include this.<br /><br />TIA,<br />Mark
mark munro
Re: 1990 Evinrude 225 stator output
I checked the stator output on a friends Rude 150 and he has 20VAC at idle and up to 50VAC at a few thousand RPM. I have about 10VAC to 13VAC which I figured was way to low but I didn't check that after the resistance check.
seahorse5
There is no output test for the stator alone, just resistance and shorts to ground. The output test for the charging system is about 6 amps at idle, 25 amps at 1000, and 35+ amps above 2800rpm.
