1990 Evinrude 115. Tried everything. I think it has a Gremlin
hrairguitar
I'm really hoping someone can please help me with this.
I bought the boat /motor back in December. Was told it needed a rebuild. So I shelled out the money to have it done. I went through the break in process. It would start easily at the launch on a cold start. Although starter sounded bad so I replaced that. However every time after I ran around for 15-30 mins and dropped trolling motor to fish for an hour and then attempted to restart it just cranks over and over with no spark/turn over. It'll take several mins of cranking to get it back up if it decides to start. Or it won't start and ill wait a while and try again until it eventually fires up. This has been happening constantly on every trip. When it does start I get a ton of white smoke.
So here's what's been done in attempt to fix by my mechanic....replaced ignition, new control box /throttle cables, replaced stator, replaced power pack ...all to no resolution. The next step is I've been asked to remove the silencer and take it out and spray starter fluid on the carbs to rule out it being a fuel related problem.
It always starts just fine cold start at the launch. If I restart it within 5 mins of running it starts up but after that its just constant cranking.
In the driveway on the hose there are never issues. Ill run it for 20-30 mins adjusting the throttle. Then let is sit for 20+ mins and it'll start up easily without the constant cranking. So something with it being on the water is assisting with the problem which makes it hard for my mechanic to diagnose and fix.
Any thoughts? Suggestions? Thank you in advance for any help
ondarvr
How did you determine that it wasn't getting spark when you're trying to start it?
hrairguitar
I might have mis-spoke with that statement. What I meant was it won't turn over. It'll sound like its about to but the whole system shuts down immediately. I even get a little jolt of vibration/shake on the steering wheel but it instantly stops and I have to turn key to off and start the whole process over again
emdsapmgr
Couple of idiosyncracys on these crossflows. 1. Weak ignition components tend to work when the engine is cold. Heat is the enemy of all weak ignition components, so when warm-the engine may not fire, despite constant cranking. Could be a bad stator, power pack or timer base. 2. The engine has to crank 250 rpm's in order to fire the ignition system. 3. A starter can appear weak, when it's just the starter solenoid that's the problem. Once the tips inside the solenoid get burned (with age and many cranks) the tips burn and won't transfer enough current to spin the starter the required 250 rpm's. That could included a "no crank" scenario. If that's the problem, it's a cheap fix. 4. Probably easier for the engine to start when on the trailer. No exhaust backpressure. Different story when the engine's exhaust is buried 20" underwater and the exhaust has to move all that water to get the exhaust out.
hrairguitar
I just ordered a new solenoid. That hasn't crossed our mind I guess. Was only $15 so not bad. He said the new stator and power pack were good so im ruling those out.
So the solenoid could get hot causing it to be a pain to start as well?
Honorary Supreme Mariner
Have you tested the electric primer solenoid ?-----Are you pushing the key in while cranking ?----------------Careful with too much cranking as these starters can not tolerate that !
emdsapmgr
I've seen a solenoid stick in the closed position. After running the engine for a while, then shutting it off at the dock, you may observe a whirring sound coming from under the cowling. The starter is still turning over the whole time you've run the engine. Just can't hear it turning when the engine is running. In that case the starter will probably get pretty warm, and possibly the solenoid, too.
