1990 70hp measurements
outdoorwood
1990 long shaft evinrude 70hp...<br />i need a spec sheet showing all measurements.<br />we are building a 20ft simmons sea skiff with a motorwell.<br />many thanks<br />bill mc
rickdb1boat
Re: 1990 70hp measurements
What specs do you need? This may help in determining your transom height. Cavitation plate needs to be even with the bottom of the hull+-1"<br /><br />
outdoorwood
thank you<br /><br />i also willbe measuring the total left to right swing of the back of motor to fit inside the motor well. i will make a trip up to the boat for that
