1990 70 hp Johnson issues
BrentonT
I have a 70 hp vro, it's been running really rough and is not running right at all, almost hesitating. I changed the spark plugs but it did nothing, i started the motor and disconnected the plugs one at a time and two of the three cylinders were running bad, the one actually stalled the motor out when i disconnected the spark plug any ideas what it could be, I've never owned a boat and I'm not really to familiar on outboard motors
Honorary Supreme Mariner
The first step to take is a compression test.-------Post the numbers.----And does the tell tale hose come off the side of the block or off the top of the block ?
BrentonT
Ok I'll research how to do that and get the numbers back to u, at first i thought it might be the power packs on each cylinder but that doesn't have to be the problem, all that means is 2 out of three cylinders are not running right
BrentonT
I wish i knew more about motors but i have a feeling I'm going to get very familiar with them after buying my first boat
Fed
While you're researching compression testers order yourself an "adjustable open air gap spark tester" ($10), a "multimeter" ($10) and also look for a "genuine OMC service manual" specifically for your motor.
81manatee
I want to make sure im reading you right. You pulled each ot the plug wires one at a time. When you pulled one, the motor stalled. Sounds to me like that cylinder is fine. You pulled another and noticed no difference. Sounds like that cylinder is not firing. If I'm reading you right.
BrentonT
Yeah I would take the top one out and leave the other two in then I would put the top back in and only pull the middle one then put it back then did it with the bottom one there was only one time when I pulled a plug that the motor still ran right
BrentonT
Sorry I been really busy, I have a musky tournament in 3 weeks and really need this boat running right
David Young
You really need to do a compression test. You can rent one for 'free' from most auto parts store for only a deposit. You get your deposit back when you return the gauge :)
