1990, 200 Venom idle and oil issues
Ajlifesaver
Have a 200 venom just aquired that has multiple issues. It requires a high idle throttle position to run on muffs or in the water. However it smokes like a house on fire and blows a huge amount of oil out the exhaust. It left a oily sludge on the ground and inner prop. The more throttle the more it smokes. Fuel is new with whole can of seafoam in 12 gal. and mixed at 50:1 as oil reservoir has been removed. It will not idle at low throttle. Carbs appear very clean. Compression is similar in all at 115-120 psi with high idle throttle position. It sounds like it runs smoothly when running and cranks easily. Not sure where to start with this one, any help appreciated.
flyingscott
In what position is the red handle in on the primer needs to be parallel to the motor could also be a faulty primer itself. Need he model # and does it have the OIS ignition. Really not an oil issue if it's pre-mixed sounds more like it's flooding.
Ajlifesaver
Primer tab is in the down/run position. The model no. is E200STLCEB. I don't believe it has the ois ignition sys. Also it has flooded out on me the first time I tried to start it ran a couple mins as I throttled down it went dead. Started back up ran a minute and died and flooded out. Thanks for reply.
Ajlifesaver
Primer tab is in the down/run position. The model no. is E200STLCEB. I don't believe it has the ois ignition sys. Also it has flooded out on me the first time I tried to start it. Thanks for reply.
flyingscott
Primer tab is not supposed to be down it is supposed to in line with the primer body. If it is down the motor will flood. Put up a a pic of it
Ajlifesaver
It is online with the primer in a vertical position.
flyingscott
Ok that's right i forgot they mount those horizontal make sure the primer is not flooding the motor. Then do a cylinder drop test make sure they are all firing.
Ajlifesaver
This one is mounted vertically. And I will perform the drop test and primer test. I'm out of town till Thursday so I'll post update then on the results. Thanks again.
