What size allen key do you remove the trim tab on the lower unit so you can drop it ? Thanks
B bonitoman Petty Officer 1st Class Thread starter Joined Jul 9, 2002 Messages 292 Oct 29, 2003 #1 What size allen key do you remove the trim tab on the lower unit so you can drop it ? Thanks
T The Marine Doctor Commander Joined Jul 25, 2003 Messages 2,177 Oct 29, 2003 #2 Re: 1990 120 force lower unit You do not have to remove the exhaust snout. If you have a swivel socket you can remove the 1/2 bolt that is up inside the snout.<br /><br />IN some instances you can just use a normal socket.<br /><br />TMD
