1989 Johnson 225 Cruising RPM
snard
What is a safe RPM range for cruising with the JOhnson 225. My WOT is OK at 5800 but I am always unsure what RPM is safe for an extended period of time (cruising). Are there any OEM guidelines on this? Does 4000-4500 seem OK.
Spidybot
Re: 1989 Johnson 225 Cruising RPM
Not too sure about it, but once read somewhere that 75% (4500 in your case) is safe, endlessly.<br /><br />Personally I cruise at the speed where the boat maintains a clear planning and in my case that is 2600 rpm.
wilde1j
3500 to 4500 RPM is fine. The biggest reason not to run at WOT is gas consumption goes WAY up.
