1989 Johnson 140 vro stays in SLOW mode
Shipley1203
Hello. I’m new to this forum as I couldn’t find any better answers.
I have a 1989 Johnson 140 which I have disconnected the VRO and had the carbs cleaned and everything maintained.
My problem is when ever I start the boat up it seems to immediately enter SLOW mode as it won’t go past 2500-2700 rpm and the engine will start to shake. The engine starts up and idles with no hesitation. it’s only when I go
to WOT it kicks in. I do not get any horns saying I’m overheating either.
Ive read that replacing the power pack could solve the issue or testing the temp sensors but I’m confused that if the temp sensor is bad why I’m not getting a horn.
Any advice/help is appreciated
Chris1956
Honorary Supreme Mariner
There could also be a bad diode in your wiring harness, allowing some other sensor to fool the powerpack into SLOW mode.
D/C the temp sensors and see if she comes out of SLOW. If so, troubleshoot horn wiring and test/replace sensors. Your waterpump is good? Thermostats good?
Shipley1203
I’m not sure if the water pump is “good” I know it has a **** stream but was told that this could cause the slow to activate.
I’m going this weekend to disconnect the temp sensor and if that is the problem what actions do I need to take to correct the problem? Order new temp sensor or a whole new power pack?
jakedaawg
1st step after a compression test is to determine if it's getting hot or not. Might be that SLOW is working fine.
use a temp stick or IR gun and find out what it's running at. You should be able to put hand on the top of the head any time. That's 140 or so.
Shipley1203
But it won’t rev past 2700 rpm right from the start, so even if it’s getting hot which I don’t think it is,something is triggering the SLOW system from the start.
Chris1956
Jake is just trying to make sure you don't ruin a good motor, by ignoring an overheat. The waterpump and the temp sensors could both be bad.
Shipley1203
So I disconnected the leads and it still stays in limp mode. I am getting a very week **** stream however. Any ideas other than the water pump?
boobie
When you can't find anything else wrong I have seen power packs do this.
Shipley1203
I put a heat gun to it and only the starboard heads are getting above or at 200 degrees but I’m not getting a horn. Could my horn circuit be fried and that’s why it’s staying in slow mode? Also what to do if only one side of the heads is overheating?
Shipley1203
And correction to this **** stream. My hose had a hole in it so it wasn’t getting enoug water.
jakedaawg
So, since it hit 200 first:
do a compression test. This is now a must. No sense spending our time and your money on something that is shot.
report back. You can rent a decent guage at many part stores. Do NOT bother with the $20 dollar chinesium brands at harbor freight or many parts stores.
next, when you first turn your key one click to the right do you hear a beep. Yes, or no. Another must answer question.
these answers you provide will help one of us help steer you into solving this.
if you hear a beep we will diagnose temp sensor.
if you dont we will diagnose more.
the goal will be to buy only the stuff you need, talk you through fixing it, and get you back on the water.
it's a step by step process but more rewarding than dropping it off at a shop.
Shipley1203
I appreciate your help Jake.
I’m noT mechanically sound enough to do a compression test so that I will probably be no help on unless you can talk me through it.
I do not hear a beep when I turn the key. I also don’t hear any horn when I remove the kill lanyard which I Was told could be another root to the problem.
I apologize in advance for my lack of skills as outboards are not my cup of tea.
jakedaawg
Being primarily an electrical/electronic issue it may be difficult to help if you are not proficient with a volt/ohm meter.
jakedaawg
1st things 1st. Go to your local parts store and rent a compression guage and a remote start switch.
use a 13/16" socket and remove all spark plugs.
place one lead of remote switch on small yel/red terminal of start solenoid. Place other lead on big red post of same solenoid.
thread guage into spark plug hole for #1 cylinder. Press and hold button on switch. Watch guage pulse 5 or 6 times. Read and record result. Do this for each cylinder.
post results and then we can go further.
