1989 johnson 100 hp still run?
ayzek
Hi all,
I want to buy used boat with 100 hp 1989 Johnson. The seller say that this motor run perfect and the technician who maintains the outboard say that this outboard has ran about 400 hr and the outboard is like new despite she is old (26 year!). He say that there is no effect of years for the outboard. The only thing is how you take care and maintain the motor.
What is your opinion? Are they correct? I have no experience with this so I will be very happy to get any advices. Sorry about no high skill English, it isnt my mother tongue..
Thank you
David Young
Remember the seller and the technician 'know each other'. I would request to see a compression test on each cylinder with you watching. Take it for a test ride. If everything seems fine, it should be OK. 26 years old isn't old if it has been cared for.
emdsapmgr
Agree. Compression test is mandatory. Should be in the 95# range on each cyl. Compression variance can be 10% between high/low cyls. I'd insist on a water test, or at least to hear it run on the trailer. Shift it between gears when running. Also, check a little oil from the lower unit gearcase. (you are checking to see if there is any water in the gearcase oil.) An important question on the model number. OMC made a special hi perf model in a 100 hp that year. Was a 100"S" model. That was a desirable consumer model. The two other models were 100"W" models, which are commercial engines-not really suited for most consumer applications. So, check to see just what model you are buying.
Faztbullet
The only difference between a S and a W is cowling,jetting and gearcase.The W is the best motor for a toon or deep V boat ..
emdsapmgr
Fast is correct. The gear ratio on an XP100 is 13:26. The gear ration on a commercial model is 15:34. While the commercial might work out fine for a pontoon, you'd wind up with odd prop sizes to get it to run properly on a regular speedboat. Perhaps some loss in efficiency, too.
ondarvr
The jetting wouldn't be different unless there was some other difference that required it to be different.
