1989 Force 9.9 HP Help???
markdavis
I have a 1989 Force 9.9. The model is #92F9A, and the serial number is #1165. It would run for a while and then foul the plugs and won't restart. I rebuilt the carb., and replaced the original membrane in the fuel pump. Now I can't get it to run. It seems to have good spark and compression, so it seems to be a fuel problem, but I am out of ideas. Any help would be appreciated?? Thanks!! :confused:
rosco_59
Re: 1989 Force 9.9 HP Help???
Does the primer bulb pump up? see if there is fuel getting up to the motor first and go from there.
markdavis
At first I had no spark. Adjusting the point gap and new plugs took care of that. I ran it for a half hour or so, and it wouldn't restart. The plugs looked fouled, so I thought it was a carb problem. I cleaned the carb and replaced the needle. The carb kit didn't come with the seat (Mercruiser Parts says the seat is not replaceable). The motor started seemed to run fine. I started it and restarted it over the course of a few hours. After a total of about 1/2 hour of total run time it wouldn't start again, and the plugs looked fouled. I replaced the fuel pump membrane thinking that maybe fuel was leaking past it, but I can't get the thing to run now. The primer bulb seemed OK. I'm just plain out of ideas????
