1989 Force 85 HP bogging down?
jcm2792
I just bought a 1989 vip bass boat with a 85 HP force engine, the engine runs great out of water i can rev all the way with no problems. Once i put it in the water and go to give it throttle to get up on plane it just bogs down and shuts off.. I cleaned all 3 carbs, replaced the plugs. I was reading and it was saying my gas recirculation system, could someone point me in the right direction as to what this is, and where its located?
Thanks
jerryjerry05
Re: 1989 Force 85 HP bogging down?
The GRS is on the side of the motor(stbd).Before you start taking apart that stuff do the basics.Comp/spark test.Check the fuel pump diaphram.What is the idle set at? 750 in gear.Then check the reeds.J
