Patty Pooh
Thread starter- Joined
- Apr 15, 2003
- 90
My trim and tilt was working fine. I had to remove the band assembly fitting for the tilt cylinder and replace it because I broke it messing around with something else. The trim & tilt works but will slowing drift down until something stops it and wont hod steady. I put new trim & tilt fluid in that I bought from boaters world and bled the system of air by filling the pump up then raising and lowering the motor all the way up then all the way down about 5 times with the pump cap off. I made sure i put filled it up on each trip up. The thing is it worked fine with no problem until I changed the band assembley fitting and now it wont hold steady without slowly falling down. Any Help would be greatly appreciated. Thanks
