WildWillJAX
Thread starter- Joined
- Oct 29, 2002
- 36
Can someone tell me if the 89/125 Farce has a tell tale weeper (pee) hole outlet to indicate water flow thru the power head. If so, what is it's location?<br />The only outlet that I can confirm (other than thru the prop) are two 3/4 inch holes side by side located on the Intermediate housing center line half way down the housing.<br />Is it abnormal NOT to have a flow of water from these ports when operating using flushing muffs at lower RPM's?<br />Thanx a zillion
