Okay, I just bought this boat and it's my first step into what I would consider "real" boats. I've used a little 12 foot v-bottom fishing boat with a 4 hp Johnson on it for the past five years and just recently found myself a nice 16 foot bass boat (1989 Bass tracker 1600 TF) with a "Tracker" Johnson 90 HP on it. Anyway, today was the first chance I had to take it out and really open it up to see what it would do.
Here's what I found:
1: The boat seems to take a LOOONG time to get up on plane, about a 1/3 of a mile (roughly).
2: As I'm waiting for it to plane, the RPM's (at WOT) run about 3000, but as soon as it planes, it jumps to 5000.
3: Then once it's on plane, it starts to bounce pretty violently (I don't really know what would cause this)
The current prop that's on it is a 13.5 x 20 stainless 3 blade.
I would like to switch to an aluminum prop, which I know throws another variable in the mix, but would switching to something like a 17 or 18 pitch prop fix problems 1 and 2? Or is it something else that's causing those problems?
Also, I have a feeling that problem 3 isn't the prop, so if someone could point me in the right direction to fixing that, it would be great.
If there is any info I missed, let me know and I'll do what I can. Any help is appreciated.
Thanks, Josh.
Thanks, Josh.
