1989 85hp force
pepsi1320
first time with a outboard.my question is after I prim the fuel bulb,should it stay hard while running.when I start mine it seems the bulb is soft,I wasnt sure if that is normal.thanks
steelespike
Re: 1989 85hp force
No it won't be hard while running as the gas is being pulled through it by the pump.It should retain its shape and not collapse.
It gets hard when you squeeze it with the motor off because the carb(s) fill and the float valve cuts off the flow.
pepsi1320
Re: 1989 85hp force
tHANKS
