1989 40hp evinrude wot issues
eric570
Hello, new to the forum.
I have an 40hp non vro evinrude, I can't get the motor to run WOT, It will run ok on partial throttle. I tried cleaning the carbs, I replaced the floats and adjusted properly. Timing is set 19 degrees at wot. Tried bypassing the fuel filter, and changed spark plugs (gapped to .035)
Today I tried opening the choke lever on motor and also by the electric switch while running full throttle, the motor ran awesome at WOT. So Its pretty obvious its a fueling issue. I just dont know what to do at this point, change jets? Any help would be greatly appreciated.
Honorary Supreme Mariner
Sorry, but there is no choke lever on that motor !---------Having to use the primer indicates that the carburetors still need cleaning / attention.
