Olekristine
Thread starter- Joined
- Mar 17, 2016
- 8
My baby was having issues dying at idle or coming down off plane to idle. After which it would be very difficult to start again. The whole motor also shaked pretty badly. After replacing the fuel filter, spark plugs and fuel line with no better results i decided to rebuild the carbs.
I am very new to outboard motor repair so please be patient with me.
I soaked the carbs in Chem dip and blew out ever hole i could see with carb cleaner and compressed air. Replaced most items that came with my carb kit (some were for other models) but was hesitant to remove the low speed needle valve assembly as it looked like it had to be exactly correct. Of course i realized this after already turning the head a few times. I know i didn't get it back exactly right. Does anyone know the correct turn from all the way in? The floats are level so i don't think that is my issue.
The motor idles better with less shake but i feel like it is idling to high. If i leave it in idle or low RPM it makes a almost hick up sound and die. It will start back up and run a little while and do the same thing. Almost like its not getting enough or to much fuel. The motor runs great wide open or at mid range but struggles at low to idle speeds. Could the issue be with the lackluster adjustment i made to the low speed needle valve or something else i may have done wrong rebuilding the carb? Would adjusting the idle maybe help? Im lost on this as it is my first boat.
Another question is have has to do with the fuel pump. I have the Clymers manual (which isn't very good) and it makes it sound like my motor is supposed to be equipped with a fuel pump. However no such pump exists. The boat came with a 6 gallon remote fuel tank which the book indicates that the motor should have a fuel pump. Am i missing something here? Motor model number is TE40ELCEC.
Thanks in advance for any help.
