1989 125 Force
terjovic
While installing a new impeller kit, I removed a pin type screw on the lower unit in line & front of prop. Apparently, this has something to do with the netural gear & attaches to a rod or linkage in the lower unit. The problem is I can't seem to line in up or take apart to gain access other than the small screw hole. Any help, thanks...
QC
Re: 1989 125 Force
Welcome aboard!! I have moved this over to the Chrysler OB section. You'll get more help here. Good luck!
