jakelogsdon
Banned
- Jul 3, 2009
- 34
I was on the way to the duck blind this morning and about 10 minutes into the boat ride, the motor starting powering down. It was exactly like i was slowly letting off the throttle (no missing or spitting or sputtering at all) after it slowed to an idle with the throttle still wide open, I killed the motor to check and make sure there wasn't something wrapped up in the prop. I then just did a quick look over to make sure everything was in order and it wasn't something obvious. I started it back up and tried to run again, didn't get over 5 mph! I tried to pump the fuel bulb while under power with no results. I tried bumping and holding the choke with no positive results. Any help would be greatly appreciated!
