1988 yamaha 150etlg outboard motor (motor problems)
tony_jatz
im having problems with this engine once i take off the rpms go up then they kick down and stay at 3000 rpms .the motor always turn on never fails but, i know that this motor goes faster . i had my carbs rebuilt twice and its not helping .i also bypassed the gas tank and installed an external tank . and still the same thing . please can someone help .before i buy new carbs .
thanks
99yam40
Re: 1988 yamaha 150etlg outboard motor (motor problems)
Have you checked your compression, spark, timing, fuel pressure/vacuum, or the alarm system to see if it works?
tony_jatz
i just installed the two fuel pumps .the plugs are new ,compression is good ,.i dont know what the alarm system is lol . the fuel pressure ??? i dont know what you mean by that im fairly new at this .i by passed the fuel tank in the hull with an external tank .
thanks
99yam40
a service/ repair manual will do wonders if you plan on doing work on your motor yourself. get your hands on one, it will give the steps for testing.
look at the frequently asked question section for more info on testing fuel systems and others
