1988 omc outdrive mounting
randy985267
installing gasket on out drive mounting and noticed gasket covers oring seal around water port should that gasket make contact with oring or do i trim gasket so oring will make contact with opposing metal surface . not finding anything in manuel about this
Lou C
Nope no need to trim it just make sure the mating surfaces are clean and coat the gasket on both sides with OMC gasket sealer or equivalent.
